Heater Resistor
Old Jul 12, 2013 | 07:20 PM
ecosta221's Avatar
Default Heater Resistor
How do i take this part out? when i look at it under the dash i can only get to 2 bolts. the third seems to be hidden behind a plastic cover behind the carpet that i cant move out of the way. i need a how to on how to remove the resistor. help please?
Old Jul 15, 2013 | 01:41 PM
darksideSS's Avatar
It is a bit of a pain but with a 1/4" swivel and a short extension it can be removed. Just a heads up that screw and the one on the same side of the resistor do not have to come all the way out, only about half way. you can then pull the back side down and slide it back towards the seat and it will drop down and you can remove it.
Old Jul 15, 2013 | 02:01 PM
KCFITZ78's Avatar
Here is a small write-up that I saved when I did mine a couple years back... I probably found on this forum.
Blower Resistor 2000-2003
Blower Resistor 2000-2003 Monte’s
OLD P/N # 15304891
OLD P/N # 89018643
NEW P/N # 89019101
Blower Resistor 2004-2005 Monte’s
P/N # 15827470
The job is not difficult, just painful as you are trying to work under the passenger side of the dash. Put a folded blanket or something along the rocker to soften the blow.
Tools required: 1 Torx 15 size screwdriver to remove fan motor
1 7/32 size socket or nutdriver to remove resistor
Massive amounts of patience once you find out how stupid a place the resistor is located (against the firewall with 2 screws in the back)
How to: Remove the fan motor, (3 t15 size screws) it will be easier than working around it. You should now be able to see the plug for the resistor and 2 of the 3 retaining screws. Remove the front screw and loosen the second. You shouldn't have to remove the second or even loosen the third as the resistor assembly holes are open to the outside edge (Think of a "C" instead of an "O") You will have to force your socket against the rubber insulation to get a good hold on the screw head, frustrating, but not impossible.
Installation is the reverse.
Old Jul 16, 2013 | 01:37 PM
darksideSS's Avatar
OLD P/N # 15304891
OLD P/N # 89018643
NEW P/N # 89019101
P/N # 15827470
That is a decent write up but the size socket listed for the blower resistor is not the actual correct size. The correct size is in fact a 5.5mm. Also it is not necessary to remove the blower motor.
Darius Lovehall
Aug 1, 2011 04:52 PM
Darius Lovehall
Apr 25, 2011 05:50 AM
Gupper
Dec 4, 2007 03:56 PM
MonteRosa
Aug 24, 2007 06:10 PM
willysmith
Aug 20, 2006 04:28 AM
