5th Gen ('95-'99): Heater core hose
Old 02-05-2021, 04:33 PM
wiggync's Avatar
Default Heater core hose
Howdy,
This might be a dumb question but I simply do not know 😂 My 1996 Monte is leaking from what looks like one of the heater core hoses. Is there a part number of some raw stock hose. This my daily driver to work and I try to fix it myself when I can.
Old 02-05-2021, 11:24 PM
Default Old school spring clamp adios!!!
Those factory installed spring clamps lose tension over time. The constant changes in temp break them down. Get some screw type stainless clamps.
The heater heater hoses, like radiator hoses, should be changed in pairs. Expect to lose antifreeze during hose replacement. Good luck.
Old 02-05-2021, 11:35 PM
IMO I wouldnt use bulk hose. Ive not had good luck with it not kinking in applications where it needs a notable bend.
Instead I'd go on rockauto and buy the replacement molded hose (it'll be under the Heater AC > Heater hose section). They're less than $10.
Old 02-05-2021, 11:43 PM
I disagree. There's nothing wrong with stock style spring clamps as evidenced by his original ones lasting 25 years. A brand new set of clamps with new heater hose will likely hold up until this car is in the junkyard.
Screw type clamps are easier to work with but have several disadvantages to spring clamps.
sishasmonte
06-21-2019 03:40 PM
RyleDup0766
02-05-2013 11:57 AM
brendan127
05-12-2012 10:39 PM
Franks 03SS
09-05-2011 12:41 PM
pongogo3
02-20-2010 10:29 PM
Quick Reply: 5th Gen ('95-'99): Heater core hose
