5th Gen ('95-'99): Heater core hose
Old Feb 5, 2021 | 04:33 PM
wiggync's Avatar
Default Heater core hose
Howdy,
This might be a dumb question but I simply do not know 😂 My 1996 Monte is leaking from what looks like one of the heater core hoses. Is there a part number of some raw stock hose. This my daily driver to work and I try to fix it myself when I can.
Old Feb 5, 2021 | 11:24 PM
USPatriot1963's Avatar
Default Old school spring clamp adios!!!
Those factory installed spring clamps lose tension over time. The constant changes in temp break them down. Get some screw type stainless clamps.
The heater heater hoses, like radiator hoses, should be changed in pairs. Expect to lose antifreeze during hose replacement. Good luck.
Old Feb 5, 2021 | 11:35 PM
IMO I wouldnt use bulk hose. Ive not had good luck with it not kinking in applications where it needs a notable bend.
Instead I'd go on rockauto and buy the replacement molded hose (it'll be under the Heater AC > Heater hose section). They're less than $10.
Old Feb 5, 2021 | 11:43 PM
I disagree. There's nothing wrong with stock style spring clamps as evidenced by his original ones lasting 25 years. A brand new set of clamps with new heater hose will likely hold up until this car is in the junkyard.
Screw type clamps are easier to work with but have several disadvantages to spring clamps.
sishasmonte
Jun 21, 2019 03:40 PM
RyleDup0766
Feb 5, 2013 11:57 AM
brendan127
May 12, 2012 10:39 PM
Franks 03SS
Sep 5, 2011 12:41 PM
pongogo3
Feb 20, 2010 10:29 PM
