Heat & Ac Problem?
Old Nov 24, 2013 | 10:34 PM
killerBee's Avatar
Default Heat & Ac Problem?
I got a problem going on with my heat and ac. U turn it on high and it comes out like its on low. What could this be? Thanks
Old Nov 25, 2013 | 05:58 AM
Try changing out the blower motor resistor. Commonly when you loose speeds, that's the culprit. It's under the passenger side of the dash, towards the firewall.
Old Nov 25, 2013 | 07:40 AM
killerBee's Avatar
Thanks I'll order one today!
Old Nov 25, 2013 | 08:50 AM
You can also get one from your local auto parts...
I got one for mine from advance auto parts a cpl yrs ago.
Old Dec 3, 2013 | 01:58 PM
killerBee's Avatar
I replaced it, didn't do any thing. What should I check out know?
Old Dec 3, 2013 | 05:13 PM
Sadly not off hand. The blower motor resistor is typically the culprit for this issue. If that's not doing it, I'd wonder if the problem is in the HVAC control unit??? But I'm at a loss...
fordwhupper
Oct 25, 2016 06:19 PM
DerrtyD
Feb 27, 2014 07:27 PM
CuttyKev
Oct 2, 2006 10:26 PM
USELESS
May 1, 2006 09:34 PM
mcarloss04
Nov 21, 2005 11:38 AM
