Heat & Ac Problem?
Try changing out the blower motor resistor. Commonly when you loose speeds, that's the culprit. It's under the passenger side of the dash, towards the firewall.
Sadly not off hand. The blower motor resistor is typically the culprit for this issue. If that's not doing it, I'd wonder if the problem is in the HVAC control unit??? But I'm at a loss...
fordwhupper
Oct 25, 2016 06:19 PM
4th Gen ('81-'88): Are my A/C & Heat connected to my computer
DerrtyD
Feb 27, 2014 07:27 PM
USELESS
May 1, 2006 09:34 PM
