headlight problem
Old May 4, 2010 | 12:55 PM
thomasm4425's Avatar
Default headlight problem
hey all....
im new here and im having a problem with my pass. side headlight. first of all the dim light went out so i replaced the bulb and that didnt fix the problem. a couple days later my pass side bright started to flicker and now does nothing. the indicator on the dash shows highbeam out but the bulb is fine. anyone have any ideas here???
i removed the headlight assembly and the wire harness has power going to two of the pins. im not sure which pins are supposed to have power. does anyone have a wiring diagram of the harness???
Old May 4, 2010 | 12:56 PM
Have you checked all the fuses?
Old May 5, 2010 | 07:51 AM
pizzarrhea's Avatar
Are you using HIDs ;D
Old May 5, 2010 | 10:29 AM
tmaupin4425's Avatar
all the fuses are fine... no hid's
edx2x
Jan 22, 2013 06:13 PM
Chris322
Dec 8, 2009 04:29 PM
MonteLSV6
Aug 2, 2009 10:59 PM
michael
Jun 15, 2008 03:38 PM
White05LT
Apr 16, 2008 12:47 AM
