head lights aren't working
whats up fellas, my haed lights aint working, i checked all the possible fuses and nothing.. if anyone can help me with this problem id sure appreciate it. could it be a relay? if so which one?
[IMG]local://upfiles/4144/0301BF4B906F44CBA6F576059E490C01.jpg[/IMG]
[IMG]local://upfiles/4144/6507CB4DFC84486DB6E3D9EF4F100BBC.jpg[/IMG]
Hi Tito, from the SunShine State.
It could be a bad light switch.
Do you have a electrical tester, to test wires for power ?
Be Patience, and I am sure that other MCF Members
will post their suggestions/solutions/comments.
Also, use the MCF Search Engine for same/similar problems.
Good Luck
Great Looking Monte
Very Limited Production
Maybe I took 'em... [:-]
Na just kiddin' I'm with Space though, you might see if you can't check your light switch, I've heard of those going bad. I take it you did check to make sure the bulbs weren't just burnt out?
My suggestion would be to check areas along the whole headlight line to make sure it's getting power with a little electrical tester. Obviously, if you find a spot where there is current, then keep following forward until it stops. That'll tell you where there's something bad. I can't see how the whole line would be good, and you still aren't getting light.
The long way, but it is the simplest, and foolproof, at that.
Snolan860
14
May 20, 2010 09:07 PM
