head lights aren't working
whats up fellas, my haed lights aint working, i checked all the possible fuses and nothing.. if anyone can help me with this problem id sure appreciate it. could it be a relay? if so which one?
[IMG]local://upfiles/4144/0301BF4B906F44CBA6F576059E490C01.jpg[/IMG] [IMG]local://upfiles/4144/6507CB4DFC84486DB6E3D9EF4F100BBC.jpg[/IMG] |
RE: head lights aren't working
Hi Tito, from the SunShine State. It could be a bad light switch. Do you have a electrical tester, to test wires for power ? Be Patience, and I am sure that other MCF Members will post their suggestions/solutions/comments. Also, use the MCF Search Engine for same/similar problems. Good Luck Great Looking Monte [:-] :eek:Very Limited Production :eek: |
Maybe I took 'em... [:-]
Na just kiddin' I'm with Space though, you might see if you can't check your light switch, I've heard of those going bad. I take it you did check to make sure the bulbs weren't just burnt out? ;) |
My suggestion would be to check areas along the whole headlight line to make sure it's getting power with a little electrical tester. Obviously, if you find a spot where there is current, then keep following forward until it stops. That'll tell you where there's something bad. I can't see how the whole line would be good, and you still aren't getting light.
The long way, but it is the simplest, and foolproof, at that. |
