PO300 missfire
Old Jan 5, 2012 | 10:21 AM
06LTMonte's Avatar
Default PO300 missfire
I had a guy check the codes after the light went one and showed this code but when he checked what was miss firing he saw upward number movement on cylinder 3 only what can cause this and can this be really bad?
Old Jan 10, 2012 | 11:18 PM
vincent e's Avatar
i had the same thing happen to me a few weeks back .thought i had a bad spark plug
or wire or coil pack .. turned out it was a bad fuel pressure regulator. if the car acts
like its missing on acceleration that could be a sign . my local chevy dealer fixed mine
for free ... government recall .call your chevy dealer.
Old Jan 11, 2012 | 08:09 AM
06LTMonte's Avatar
I called them they said no recalls.....where do u live that this was done? Sorry for the bother but 120 just to tell me whats wrong is alot of money
Old Jan 22, 2012 | 05:48 PM
vincent e's Avatar
i live in omaha neb. on 2 jan 2012 went out to start car then heard a loud boom .
it turned out fuel had been leaking into the intake from a bad fuel pressure regulator
causing an explosion . the explosion blew a hole the size of fist in the intake and shot
the engine cover 20 feet into the air. this only applies to 3800 v6 motors my monte is
a 2000. my dealer fixed everything for free the only thing i had to pay for was a new battery . now with your car being an 06 i dont think its covered in the recall because
if i remember right the 3800 v6 was replaced by the 3500 v6 that year.
Old Oct 15, 2016 | 09:04 PM
RickCoMatic's Avatar
PO300
PO403
PO405
PO446 ✴︎ ⬅︎ ⬅︎ ⬅︎
All these Codes were triggered by a faulty FUEL TANK PRESSURE SENSOR!
Wait for the Low Fuel Warning before attempting to DIY.
Start engine.
Pull FUEL PUMP Relay ... Let Engine stall to relieve pressure in system.
Remove GROUND Wire from Battery.
With car Raised and SAFETY STANDS securely in place.
Support Tank with Jack.
(I made a "Jig" to attach to the Jack. Sawed the square bottom off from Milk Crate. Drilled holes through Hockey Puck. Mounted Puck to center of Milk Crate with Heavy Duty Zip Ties. Affixed carpet to other side of Milk Crate bottom for padding.)
Lower tank enough to access Sensor atop Fuel Pump.
Unfasten Pigtail from Sensor.
Unclip and Remove Sensor ••• Straight-up.
DO NOT BREAK THE END OF SENSOR OFF INSIDE PUMP!!!
If you need a Charcoal Canister do it when you replace Sensor.
Removing Relay to releive Pressure throws a Code which may require a MIL Light reset.
Mean_pig
Oct 15, 2016 09:05 PM
LittleE
Apr 8, 2015 12:31 AM
Curtis24682007
Apr 16, 2014 05:14 AM
monte07
Jan 10, 2011 01:49 PM
bustedgto@live.com
Nov 30, 2010 08:04 PM
