has anyone changed the fan settings on 06-07? updated for mickey
My warrenty is up on my 06 monte and was going to flush the dexjunk out put in some prestone. I will also be adding a 180° Tstat but I havent been able to find a aftermarket fan switch set up. I had got one for my GT at the Wbody store but the dont have one for the 06-07 Monte anybody have any other place to look?
if ya find one for the 03 monte SS let me know i would love to lower the T-stat settings. ya now i have ran this car for 4 years and if i have ever had the fans kick in i havent heard them yet.
ORIGINAL: mickey
Purpose: To be able to manually turn on and off the fans. This is so that while in the staging lanes or in heavy traffic, I can manually override the system's ability to turn on the fans and cool the engine better.
How its done: [/b]
Step 1: Go to Radio Shack, get a switch part #2750653, and a pack of diodes part #2761114. You will also have to get some 16-18 gage wire.
Step 2: Get the switch ready. You must solder a jumper wire and one diode on the terminals of the switch. Make sure the diode is as in the picture below. Number 2 pin has to be grounded to the car.
Step 3: Open the fuse box under the hood. You must now run two wires from the relays to the switch under the dash. (There is a rubber plug in the fire wall in front of the brake pedal.) Strip wires 1/2 inch and connect numbers 1 and 3 pins to the 4[/color]5 and 6[/color]7 marked in the fuse box in the pictures below. After placing the wires in the fuse box, reinstall the relays. It would be much easier for you to use different colored wires for this. If you choose to use the same color wire as I did, just connect the wires to 8[/color]9 and 10[/color]11. You have a 50/50 chance on getting it right. If you connect the wires correctly, both fan-1 and fan-2 should be either on high, or on low. If not, change wires 12[/color]13 and 14[/color]15 in fuse box around. If that doesn't work, there is a different problem and you should go over your work.
[align=center](Click images to enlarge) [/align] [align=center]
[/align] Step 4: The lid for the fuse box now needs a notch just big enough to run the wires out of it at the top where it seals together.
I mounted My switch here (the BLUE one)
This is the housing that also holds the switch for the seat heater.
mousehousemoparman
Sep 11, 2011 09:33 PM
phillip9698
Apr 30, 2010 08:37 PM
