Fuse panel... Power only when car is running ?
Hello guys, I need to hook a GPS up to my fuse panel, it is peminantly hooked up built into the dash. I only want power to it when the car is either running, or the accessory is on. I have one of the fuse "Tap" ins for the power. What fuse would you suggest I use ? Also, where would a good ground place be for the negitive side ? Thanks as always...mjclemm
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
6th Gen ('00-'05): A/C only blows hot air from both sides only
Raider
06-18-2014 11:15 PM
skidoo6713
02-10-2010 11:36 PM
