Fuse panel... Power only when car is running ?
Old Jun 23, 2013 | 01:58 PM
MJClemm's Avatar
Default Fuse panel... Power only when car is running ?
Hello guys, I need to hook a GPS up to my fuse panel, it is peminantly hooked up built into the dash. I only want power to it when the car is either running, or the accessory is on. I have one of the fuse "Tap" ins for the power. What fuse would you suggest I use ? Also, where would a good ground place be for the negitive side ? Thanks as always...mjclemm
Old Jun 23, 2013 | 04:50 PM
Enzo354's Avatar
STILL SLOW
A really easy way is to get a test light and start poking around. Find a fuse with a 20 amp rating and plug it in. I have never had an issue doing it like that.
Old Jun 23, 2013 | 05:57 PM
X2
Run the ground to anything steel under the dash... or tie it in to a factory ground.
Old Jun 23, 2013 | 06:05 PM
MJClemm's Avatar
Originally Posted by STUMPMI
X2
Thanks guys... That's EXACTLY what I did.... Worked out great..... Now I have a GPS BUILT in to the dash... (Used the center left air conditioner duct). Ill post a pic in a lil bit..... Thanks again....
Raider
Jun 18, 2014 11:15 PM
benhillzone3
Oct 29, 2013 10:59 PM
shotime105
Dec 11, 2012 03:40 PM
02CHEVYMONTESS
Nov 11, 2012 04:13 PM
skidoo6713
Feb 10, 2010 11:36 PM
