6th Gen ('00-'05): Fuel pump not priming
Old Feb 17, 2021 | 09:33 AM
Father Torque's Avatar
Default Fuel pump not priming
The fuel pump on my 3.4 2004 monte carlo ls no longer primes when the key is in the on position.The fuel pump relay still clicks. No issues when the car is running . Just a few hard starts when the car is sitting for a while.
Old Feb 18, 2021 | 02:39 AM
xpage's Avatar
check fuel pressure. could be a bad regulator or leaking one way valve in the fuel pump assembly. hard starts likely indicate a leaking check valve in the fuel pump, if that is the case your fuel pressure will drop after the key on ignition off initial fuel pump prime
Old Feb 21, 2021 | 03:14 PM
It wound up being the fuel pump. Didn't think it was the regulator since I replaced it last year. Thanks for the reply.
zeuster3gm
Feb 19, 2017 11:58 AM
lyskor
Sep 1, 2016 11:16 PM
fiveirontimmy
Mar 23, 2016 05:55 PM
JoeD
Apr 4, 2014 09:48 AM
JoeAsheville
Feb 16, 2009 01:05 PM
