Rewiring a fuel pump
Old Apr 2, 2014 | 08:17 PM
JoeD's Avatar
Awaiting Email Confirmation
Default Rewiring a fuel pump
Does anybody know if I can Rewire a fuel pump from my igntion using a relay straight to the pump
Old Apr 2, 2014 | 08:43 PM
03SSLE's Avatar
Without some type of safety device inline with your power the pump will constantly run as long as the ignition is on. That means if you get in a wreck and can't turn the key off you will still be pumping fuel - possibly out of a ruptured line. Very dangerous idea - and NOT RECOMMENDED.
Old Apr 2, 2014 | 09:07 PM
JoeD's Avatar
The relay I have has a inline fuse but what else should I do I'm not getting fuel pump power at all
Old Apr 3, 2014 | 06:12 PM
JoeD's Avatar
Anybody??
Old Apr 3, 2014 | 08:28 PM
nitehawkjcb's Avatar
Check your fuel pump relay. Or just run a new power wire from the relay and make sure your grounds are good.
Old Apr 3, 2014 | 09:35 PM
JoeD's Avatar
So it's ok to use a relay as long as it has some type inline fuse??
Old Apr 4, 2014 | 08:05 AM
JoeD's Avatar
Old Apr 4, 2014 | 09:13 AM
turbo monte's Avatar
Why do you want to do this? Just buy a racetronix rewire and be done with it instead of trying to make your own lol
Old Apr 4, 2014 | 09:48 AM
JoeD's Avatar
My fuel pump isn't getting any power no one seems to know why dealer simple said reace whole car harness but I tested it out the car an it started working with the four counter relay
ReaperSS
Aug 29, 2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
clucia01
Mar 20, 2011 10:17 PM
smolek37k
Nov 1, 2006 07:11 PM
Monte Python
Jul 11, 2005 02:56 PM
