Fuel pump losing prime?
Old Jul 25, 2011 | 01:03 PM
artlawton's Avatar
Default Fuel pump losing prime?
I have a 2000 Monte Carlo that takes a lot of cranking to start. If it sits for an hour or so, you have to crank it and pump the gas pedal to get it to start. I believe the fuel pump is losing its prime. If that's the problem, do I need to replace the pump or is there an easier fix? Any suggestions would be appreciated. Thank you!....scott
Old Jul 25, 2011 | 01:18 PM
First, pumping the gas on these cars is not like an old carb-ed vehicle. Until the car is started, pumping the gas does nothing.
First think I am wondering is if you have any type of fuel leak. Check under the car for smells of gas and signs of wetness. If so, it may be a very slow leak resulting in the lines being dry of fuel, hence why it cranks a long time before it starts.
If you can get your hands on a fuel pressure tester, you can check the PSI at the fuel rail. See if it's right.
Also, check for signs of any vacuum leaks. A big enough leak can cause some starting problems.
How do the car run once it's started?
Old Jul 25, 2011 | 01:46 PM
artlawton's Avatar
Default Your response
Thanks very much for your suggestions. I did replace the fuel filter last year. I'll check and see if there may be a small leak in that area.
After the car starts, it runs well. Thank you again!......scott
ReaperSS
Aug 29, 2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
zipper
Oct 21, 2011 05:54 AM
Bitchnbobb
Mar 26, 2011 08:03 PM
Ol skl SS
Oct 10, 2007 06:06 PM
