6th Gen ('00-'05): Fuel Pressure
#61
I recall early years of the 3100 were notorious for the passage between the intake and EGR clogging. I have not seen that as much on the modern LA1 3400, but clearly still happens. Considering you mentioned the EGR has a wiring harness spliced in that has all white wires, I would try and get a junk yard harness, fix it back to a factory harness, matching colors properly and get an EGR for this engine that uses the factory plug. Avoid chasing down problems from using aftermarket parts that are not a direct replacement. And to be honest, I would not hesitate using a junk yard EGR as long as they don't charge much for it. I honestly don't recall ever hearing one fail on a 3400 (I am sure they do, but my guess is that it is pretty rare).
#63
The way you describe that sounds like a faulty sensor or solenoid somewhere. If you are still having EGR problems, this can be part of those issues. Are you still throwing codes for any issues?
#64
still the same closed position code was getting . Found a wiring diagram lastnite and looked and its wired up correctly as long as A,B,C,D go in that order on piogtail from left to right. Problem is my wires are faded i believe. I have Red,Brown< (no black wire, grey with black stripe(x2) and a yellow and whit stripe and yellow black stripe???
#65
I did some looking myself. This is the exact wiring for the EGR in a 2000 Monte with a 3400. And if your pigtail connector is NOT this connector, I strongly suggest you abandon this, get a OEM type and the correct connector (even if it involves going to the junk yard to get the parts). This is one of the reasons I HATE replacement parts that want you to cut the factory connector and splice in their connector. Fuel pump assemblies are notorious for that. I will skip and go with an OEM style connector any time.
But this can be related to that performance problem because the EGR is not functioning as it should.
