Front parking light issue
Old 07-06-2012 | 02:20 PM
David_p35's Avatar
Default Front parking light issue
I have a problem, I have no working front parking lights. Rear park lights work, headlights, turn signals, and drl's all work. Has anybody had this problem and if so what was the repair for it. I've run out of ideas on what to test?
Old 07-06-2012 | 03:22 PM
03SSLE's Avatar
Welcome to the forum. Do your dash lights work? If not, check the FRT PARK LP fuse in the panel on the end of dash passenger side.
Old 07-06-2012 | 05:47 PM
aussiek2000's Avatar
what year monte?
Old 07-07-2012 | 09:22 AM
David_p35's Avatar
Fuses are good, as is the relay.
Old 07-07-2012 | 09:24 AM
David_p35's Avatar
It is a 2004
Old 07-11-2012 | 04:39 PM
dave countie jr's Avatar
this might be stupid,but are the bulbs good/ also to change them you'll have to take the headlight assembly out of the car. it's easy, been there done that Good luck Dude.
Old 07-11-2012 | 09:36 PM
You're going to have to check to see if you have power, ground, or neither. I can assist you from there.
jwjones
10-06-2019 09:39 PM
shock081
07-14-2010 10:00 PM
Mike03R1
05-25-2010 09:03 PM
Mike03R1
05-23-2010 08:18 PM
Soulja
09-13-2006 04:25 PM
