Front parking light issue
Old Jul 6, 2012 | 01:20 PM
David_p35's Avatar
Default Front parking light issue
I have a problem, I have no working front parking lights. Rear park lights work, headlights, turn signals, and drl's all work. Has anybody had this problem and if so what was the repair for it. I've run out of ideas on what to test?
Old Jul 6, 2012 | 02:22 PM
03SSLE's Avatar
Welcome to the forum. Do your dash lights work? If not, check the FRT PARK LP fuse in the panel on the end of dash passenger side.
Old Jul 6, 2012 | 04:47 PM
aussiek2000's Avatar
what year monte?
Old Jul 7, 2012 | 08:22 AM
David_p35's Avatar
Fuses are good, as is the relay.
Old Jul 7, 2012 | 08:24 AM
David_p35's Avatar
It is a 2004
Old Jul 11, 2012 | 03:39 PM
dave countie jr's Avatar
this might be stupid,but are the bulbs good/ also to change them you'll have to take the headlight assembly out of the car. it's easy, been there done that Good luck Dude.
Old Jul 11, 2012 | 08:36 PM
You're going to have to check to see if you have power, ground, or neither. I can assist you from there.
jwjones
Oct 6, 2019 08:39 PM
shock081
Jul 14, 2010 09:00 PM
Mike03R1
May 25, 2010 08:03 PM
Mike03R1
May 23, 2010 07:18 PM
Soulja
Sep 13, 2006 03:25 PM
