where is the LOW side?
Old Jul 6, 2012 | 04:53 PM
dave countie jr's Avatar
Default where is the LOW side?
Hi Kids, I need a shot of freon for the A/C where do u put it in? Where is the low side and how much do u put in ? I dont need much. the air comming out is right at 55` but i want it just a tad bit colder.
Old Jul 6, 2012 | 05:12 PM
I hope the below link helps you stay cool...Good Luck..
If it doesn't help, check back to see what our expert tech's post & also check out MCF search engine..
How to Install Freon in a Monte Carlo | eHow.com
Click above link
Old Jul 6, 2012 | 07:07 PM
Typically ac is good for 40 degrees lower than ambient temp. I wouldn't go putting Freon in if you don't need it. You can do a good amount of damage.
With that said, it's the port on the rear of the engine.
Old Jul 7, 2012 | 05:51 AM
aussiek2000's Avatar
How hot is it outside? How long was the AC running? Driving or idle?
Old Jul 8, 2012 | 09:59 AM
Default low side
yesterday in St Louis it was 107` a/c was on for about 1 hr 10 min @ 55` and i was driving the car on I 64 going to Scott AFB.
Old Jul 8, 2012 | 10:13 AM
Hi Dave, thanks for your update..Was your a/c working ?
Was it cool enough 4 -Sure...Did you read the infor in below link & did it help ? Thanks member's for posting your help
Click above link
Good Luck `Dave & I hope U stay cool driving your Monte
Old Jul 8, 2012 | 10:14 AM
Default low side
Click above link
thanks space. the temp in st louis yesterday was 107` and the air is @ 55` or so. and the car is running down the hwy at 70 mph. do i need to do this? chibi sez a 40`diffrence is ok. i would like to get about 6` cooler.
Old Jul 8, 2012 | 02:15 PM
03SSLE's Avatar
If the ambient temp was 107° then your A/C is working perfectly fine putting out air at 55°. About the only thing you can do is make sure you have it set for recirculated air and not outside air.
Old Jul 8, 2012 | 05:26 PM
Yep, your AC is working fine. I can't drop mine below high speed when it is over 100*.
Old Jul 8, 2012 | 07:49 PM
Yup working fine thats what mine has been running at & i just recharged it a week ago
