Front hub replacement - difficulty?
Old Feb 9, 2012 | 06:23 AM
I've used Timken bearings recently to replace 1 bearing on the Monte, 2 on my wife's '05 Impala and one on the '94 Grand Am. No issues. So far, a happy camper.
And, if I'm not mistaken, they are made in Ohio, so not the cheap-o Chinese stuff. For once something to help the U.S. economy and workers....
Old Feb 20, 2012 | 11:08 AM
JaxJim's Avatar
Well, I replaced the wheel bearing/hub assembly on the Lumina this weekend. It went well. I bought the hub assembly from Advance Auto - off their web site. List was $89. With a few other items, my order was over $100 - so, I got 15% off and a $50 coupon towards a future order. Shipping was free. Net cost on the bearing - $26. I used some "loaner" tools from O'Reilly - 36mm socket, torque wrench and a hub puller - the tools made the job fairly easy. No more bearing noises. Nice and quiet now. The hub assembly was from Federal-Mogul, three year warranty. Made in Korea printed on the box. I hope those Korean's make a good bearing - it wasn't a difficult job to R&R, but I don't want to have to do it again any time soon.
Old Feb 20, 2012 | 06:20 PM
boggie's Avatar
would a ball joint fork work just as well
Old Feb 20, 2012 | 09:46 PM
JaxJim's Avatar
ball joint fork, hammer, prybar, probably all would get the hub off the axle. Mine didn't appear too tight. As a matter of fact, all the bolts including the axle nut came off with relative ease. All the you tube videos showed people removing the hub with hammers. Since I could get a hub puller for no charge, that's what I used. Real easy that way.
Old Feb 20, 2012 | 10:39 PM
mwjames's Avatar
generally if ya change 1 hub assembly you minds well change the other one to. example replace both fronts at same time, or both rears at same time. i just finished putting new hub's all around on mine along with all new brakes
Old Sep 14, 2012 | 11:05 AM
Johnathan Hibdon's Avatar
is it the same size on the 06 monte carlo i need to find the axle nut size anyone know i was thinking 35mm but not sure
bossross
Jul 29, 2015 06:53 PM
2002 SS
Mar 10, 2014 09:21 AM
owens91
Jan 13, 2013 12:17 PM
rex85cc1
Jun 30, 2010 02:31 PM
RickCoMatic
Apr 9, 2008 09:22 PM
