Front axle nut torque spec
Old Feb 15, 2012 | 12:26 PM
jasonsmith's Avatar
Default Front axle nut torque spec
I've got an 02 Monte LS.
I replaced the front axle and in my manual. The torque spec is 118 ft/lbs. So that is what I torqued it to.
I've seen in some places here and other places list a 159 ft/lbs torque spec for the front axle nute.
Which one is correct? And if it needs to be at 159 ft/lbs, is it okay to just torque it down as is? Or would the nut need to be replaced? I've got around 100 miles on the new axle.
Old Feb 15, 2012 | 01:39 PM
In the service manual of my 2000, it did specify 159ft/lbs.
Maybe it was changed? Maybe the TQ spec is different for an LS? (which I doubt).
If your book says 118, that is what I would do.
(I won't reply this again to your PM )
Old Feb 15, 2012 | 01:55 PM
jasonsmith's Avatar
I ended up torquing it down to 159 ft/lbs.
Old Feb 15, 2012 | 05:13 PM
I've used an impact gun and tightened the axle nut down to the point the impact gun stops going. Has not been an issue on any car I've worked on so far.
Old Feb 15, 2012 | 06:25 PM
chevynick08's Avatar
<A href="http://gsi.xw.gm.com/newsi/showDoc.do?laborOpCode=&docSyskey=689767&cellId=61 782&pubObjSyskey=4293044&from=sm&pubCellSyskey=101 4369#N65756">Installation Procedure
1. Install the front wheel drive axle (1, 2) into the transaxle.
2. Verify that the front wheel drive shaft retaining ring is properly seated:
Grasp the inner housing and pull the inner housing outward. Do not pull on the front wheel drive axle shaft.
The front wheel drive axle will remain in place when the front wheel drive shaft retaining ring is properly seated.
3. Install the front wheel drive axle into the front wheel drive shaft bearing.
4. Connect the ball joint to the steering knuckle. Refer to Lower Control Arm Ball Joint Replacement in Front Suspension.
5. Connect the outer tie rod assembly to the steering knuckle. Refer to Steering Linkage Outer Tie Rod Replacement in Power Steering System.
Notice: Refer to Fastener Notice in Cautions and Notices.
6. Install a new front wheel drive shaft nut. Insert a drift or a flat-bladed tool into the caliper and the rotor to prevent the rotor from turning.
Tighten
Tighten the nut to 160 N·m (118 lb ft).
7. Install the stabilizer shaft link. Refer to Stabilizer Shaft Link Replacement in Front Suspension.
8. Install the wheel and the tire. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
9. Lower the vehicle.
10. Inspect the transaxle fluid level.
11. Inspect the wheel alignment. Refer to Wheel Alignment Measurement .
This is From the Gm Online Information
Old Feb 15, 2012 | 06:54 PM
jasonsmith's Avatar
Sometimes GM later on does revisions that don't show up in the manual. I know on another car GM had later changed the torque spec on the rear axle nut, but the manual never updated to the revision.
Strange how one year would be 159 ft/lbs, the next year 118 ft/lbs. Also possible it could be a mistake.
Though if a shop tightened it down, then it would probably be way over 200 ft/lbs anyways with their impact wrenches they always use. Never seen a tech use a torque wrench.
Old Feb 15, 2012 | 07:18 PM
yea ive heard the whole "theory" behind using an impact is that the hamering action of the gun could smash the bearings into the bearing race and put indentions in the race which could cause noise but i personally have never had this problem i usually just use an impact and spin the rotor at the same time.
Old Feb 15, 2012 | 08:11 PM
jasonsmith's Avatar
I've read of some guys going through alot of hubs and/or axles. I kinda wonder if they were over tightening the axle nut and that might could be the problem.
SSilver
Mar 18, 2013 08:47 AM
MonteDriver
Mar 10, 2010 07:15 PM
tridski
Feb 15, 2010 07:15 PM
NICK700R
Jul 25, 2008 02:58 PM
reswob
May 20, 2006 02:53 PM
