FREON has to be leaking..Right?
My ac was hot, put a new radiator on her (2000 ss) it had a hair line leak. Put some more freon in her and it was perfect for like a week, started blowing hot again...Changed valve core, put more Freon in her, fine for like a week.. blowing hot again...You know freon dosentevaporate , has to be leaking right? dam I hope this isnt exspensive.
Thanks
Thanks
RE: FREON has to be leaking..Right?
Yeah actually thats what I meant. Thats what Im thinking also. I hope its not my compressor. Thanks for ya advice man. I dunno which one would be worst: hole in my lines or bad compressor[:@]... Im taking this think to an expert. THANKS.
Did you change the radiator or did you mean the condensor?? If you have changed the condensor and the heater core/ evaporator, could be something as simple as a damaged o-ring. Something else you can do is have a tech put some dye in the system and then check with a black light. Good luck.
blackmonte781
09-14-2011 08:46 PM
