FREON has to be leaking..Right?
Old Sep 29, 2008 | 08:09 PM
sinceire's Avatar
Default FREON has to be leaking..Right?
My ac was hot, put a new radiator on her (2000 ss) it had a hair line leak. Put some more freon in her and it was perfect for like a week, started blowing hot again...Changed valve core, put more Freon in her, fine for like a week.. blowing hot again...You know freon dosentevaporate , has to be leaking right? dam I hope this isnt exspensive.
Thanks
Old Sep 30, 2008 | 08:08 PM
rysZ34's Avatar
Default RE: FREON has to be leaking..Right?
Okay when you say freon you're actually talking about R-134a correct? NOT R-12. I would say you may have lines leaking or your compressor is starting to go bad. But I'm no a/c expert by ANY means.
Old Sep 30, 2008 | 09:08 PM
sinceire's Avatar
Yeah actually thats what I meant. Thats what Im thinking also. I hope its not my compressor. Thanks for ya advice man. I dunno which one would be worst: hole in my lines or bad compressor[:@]... Im taking this think to an expert. THANKS.
Old Oct 2, 2008 | 11:57 AM
MXMagnum's Avatar
Did you change the radiator or did you mean the condensor?? If you have changed the condensor and the heater core/ evaporator, could be something as simple as a damaged o-ring. Something else you can do is have a tech put some dye in the system and then check with a black light. Good luck.
iMuf
May 12, 2014 04:46 PM
blackmonte781
Sep 14, 2011 08:46 PM
98Z34
May 28, 2007 12:04 PM
orthokneepa
Sep 5, 2006 03:49 AM
White05LT
Aug 23, 2005 10:57 AM
