6th Gen ('00-'05): Finding the right lock actuator
Old Apr 24, 2013 | 10:56 PM
DarrynSami's Avatar
Default Finding the right lock actuator
The mechanical part of my door lock works fine. Am using the key and thumb button to operate the door now because I removed the electrical actuator. Power flows to the actuator when the lock switch or fob is used and I can hear the motor trying to move but nothing happens, seems the actuator is locked up internally.
The problem is that I can not find this actuator anywhere! You can see in the pic that it has three separate wire connections. I can find many places online that carry this exact actuator with only two connections. The one the arrow points to is not on the replacement actuators available. Does anyone know what this extra set of contacts is for? Can I find the same actuator? Will it hurt anything if I use the one lacking the extra contacts? Thanks for any input you have.
File Type: jpg
Old Apr 25, 2013 | 01:42 PM
DarrynSami's Avatar
Default Diagram?
Anyone have a wiring diagram for the door locks handy? That would help determine if the options available will work. Thanks.
Old Apr 25, 2013 | 03:39 PM
Old Apr 25, 2013 | 04:15 PM
03SSLE's Avatar
The actuator has 3 terminals because it is bi-directional. The center terminal is the power feed, and the 2 outer terminals are grounds. Depending on which ground is utilized to complete the circuit the door either locks or unlocks. Maybe add bi-directional to your search keywords and you might find a replacement. Another option would be to source one through a parts house.
Old Apr 27, 2013 | 03:38 AM
DarrynSami's Avatar
Default Explanation
On the pic posted above you can see three connections, one of them has 2 pins and obviously is power to the solenoid. There is a 4 pin connector that is for the lock and unlock control. My question was about the two pin connector with the arrow pointing to it, it appears to be a set of output contacts. I don't know what these contacts are for and they are the ones missing from all replacements parts available. I need to know what these contacts are for.
Old Apr 27, 2013 | 08:10 AM
03SSLE's Avatar
Have you physically seen the replacement part, or just a picture online? A lot of times the picture is only for reference and won't exactly resemble the actual part you get. My schematic is very basic and only shows the hot/ground connections. At this point the only suggestions I have would be to call and have the counterperson physically inspect the part to make sure it matches - or - pull the OE number off the actuator and call a few part houses. Hopefully you will get in touch with an experienced counterperson that knows how to use a cross reference/interchange guide to track down the correct part for you.
DerrtyD
Apr 26, 2013 11:49 AM
blackmonte781
Sep 14, 2011 08:46 PM
Splaashrafa
Dec 3, 2010 12:15 PM
widebody
Jun 29, 2010 11:03 AM
dusty96
Apr 29, 2010 07:49 PM
