Factory size tire rubs in the rear on my strut
Old Feb 23, 2012 | 08:58 AM
The SS might have gotten the FE4 suspension and you probably have the FE2/3?
If you look at optional tire sizes for the LT it says 225 width still on 17s.
I find it odd that it is only the driver's side. Did they hit the strut plate?
Old Feb 23, 2012 | 09:02 AM
Franks 03SS's Avatar
2011 Monte Of The Year
well im sure if i were to have 225's it wouldn't rub then
on mine i only tried the wheel without spacer on the drivers side, i never tried the passenger side:p
Old Feb 23, 2012 | 09:22 AM
03SSLE's Avatar
If it's only rubbing on the driver side I would suspect (as Lou mentioned) worn/damaged suspension compnonents and/or an alignment issue.
Old Feb 23, 2012 | 09:43 AM
For it to be damaged or wore u would have bigger issues sence the 2 pieces are welded to the strut that give it the clearance
Old Feb 23, 2012 | 09:57 AM
i believe only L67 montes had the 17's stock Lou
So i wonder if the struts are different then. The hubs have the same spec's and the same part numbers. I looked it up on rock auto.com.
Old Feb 23, 2012 | 10:13 AM
What suspension pkg does your Monte have Lou? FE??
Old Feb 23, 2012 | 10:36 AM
I don't know It's a supercharged 04 SS. i never saved the info from compnine when it was there so IDK
Old Feb 23, 2012 | 10:44 AM
Look at your build tag that has ypur paint code itll say it in there & its all in order so goto the Fs & ull see it
Old Feb 25, 2012 | 04:58 PM
blackbeauty89's Avatar
I suppose I'll let it rub away. It's hardly touching. The suspension must be different on the supercharged models. Oh well.
Old Mar 2, 2012 | 04:49 PM
well i removed my spacers and fixed the rubbing issue today, as you can see no more rubbing and it was only on the driver side
all you need is a small sledge hammer and some muscle! lol :p
dont mind my rusty parts
Also notice the coil spring boosters i installed haha my monte was sagging from the rear a lil so this fixed it right up and stiffened up the car a little bit more and gave it a bit better stance
i also removed my huge 4 cubic ft sub box, amp and cap. so nomore bass for me
but on the plus side, my monte feels so much better without that weight and with the rear STB back on. Which i reinstalled after i removed it to fit my sub box a lil better
KingSize
Nov 4, 2018 09:04 AM
dragonmyst
Feb 22, 2015 10:13 AM
ChibiBlackSheep
Oct 28, 2013 11:48 AM
thumpingetocar06
Jan 2, 2010 11:30 PM
KingSize
Aug 31, 2008 10:46 AM
