6th Gen ('00-'05): Exhaust manifold repair questions
Old Jun 13, 2019 | 11:39 AM
nitehawkjcb's Avatar
Not that I can think of... Just unbolting the dogbones up top IIRC
Old Jun 13, 2019 | 03:47 PM
Jesse Smith's Avatar
So far so good. Removed the 3 into 1 bolts. (Flex pipe/down pipe). Egr bolts. Front to rear manifold bolts. Removed the motor hoist bracket that has the vacuum lines attached. Now onto find these blind bolts. Looks like it should be 6 or 7 judging by the part I'm looking at online. Looks like the motor hoist bracket and the manifold share the same holes into the head.. am I right?
Old Jun 13, 2019 | 10:47 PM
Well I got it off. Definitely cracked at the weld. It was a little bit of a bitch but glad I found the culprit. Thanks again for your guys' advice!
Old Jun 14, 2019 | 12:19 AM
Glad you got it figured out.
Old Jun 16, 2019 | 09:45 AM
That sucks, but mystery solved!!
Just curious, are you going to replace it or have it welded back together?
michelob
Jul 10, 2014 10:28 AM
Shandley
Oct 2, 2012 07:21 PM
smitty911
Mar 3, 2010 05:11 PM
bumpin_monte01
Aug 28, 2005 06:05 PM
