Engine Trouble
Oil FILL not Filter. But, yes I know you can take it off while it is running, as stated about using breathers, the car should still run, but mine started to cut out, then after 2 seconds it was fine. You could put your hand on the valve cover and it feels just like a shop vac.
nope just engine theory here
and that would happen. it is the exact same thing as puttin ur hand over a shop vac hose..when u put ur hand over it the system, the vacuum will suction ur hand. if thats what u meant by a hoover its nuttin but normal
Sorry, I was Wrong again : (
Thanks Member: DeathByRice
That's what I thought you meant, but it was a fun 2 play with your post
It really sounded like zomething that Kid from `Space would `do.
Wish U & the reader a `Happy 4-Sure.
Chiefeng
08-14-2014 07:19 PM
Chelsea
02-20-2013 09:59 AM
