engine-trans bridge?
Old Apr 29, 2012 | 01:44 AM
crete's Avatar
Default engine-trans bridge?
Anyone know what an engine -trans bridge looks like? I am swapping a 2000 3.8 with a newer one and the haynes manual says to take off the engine-trans bridge. Is the just another name for a driveplate cover? They don't elaborate much.
Old Apr 29, 2012 | 10:54 PM
mwjames's Avatar
pretty sure it's just a mount, just make sure everythings disconnected you should be fine.
Old Apr 30, 2012 | 01:20 PM
crete's Avatar
thanks but which mount? I see the two bolts that are accessible through the subframe but other than that and the dogbone I'm not sure where there is another mount.
Old May 2, 2012 | 02:26 AM
mwjames's Avatar
I think the dogbones and the mount you are seeing should be it, detach it from the trans and you should be good to go if you have everything else out the way. Their should be 4 bolts on that mount in question
06mistreSS
May 31, 2013 09:44 AM
arcorriveau
Aug 1, 2011 07:55 AM
nascar43
May 26, 2011 05:42 PM
Budsjlm
Nov 6, 2010 06:43 PM
montejass
Jul 10, 2005 09:18 PM
