Sunroof motor possibly going out
Old Apr 26, 2012 | 07:19 PM
tshorty454's Avatar
Default Sunroof motor possibly going out
My sunroof hesitates every now and then when opening an closing and I'm pretty sure it might be the motor . Anyone got any onfo on where to get a new one? Besides dealer? I have googled it and really haven't come up with anything. I don't think it's the switch but well see. Any input is appreciated.
Old Apr 26, 2012 | 07:28 PM
03SSLE's Avatar
Have you applied white lithium grease on the runners to see if that helps? If that doesn't help, what year Monte is the sunroof motor for?
Old Apr 26, 2012 | 08:03 PM
Old Apr 26, 2012 | 08:32 PM
Crusader SS's Avatar
Mine was stuttering and clicking 2 yrs ago... I thought it might be the motor... Then I completely decreased the runs (sorry can't remember what I used) and re-applied white lithium grease, until today, it has performed flawlessly... Hope this helps...
Old Apr 26, 2012 | 09:12 PM
I would try to degrease it like crusader said and re grease it with a light weight grease. I think that it gets gummed up and starts sticking.(i still need to do this) Mine works but doesn't open all the way by itself, you have to hit the switch a few times.
Old Apr 26, 2012 | 09:25 PM
Originally Posted by zjerry
I found one of them in the glove-box of the 5th gen I bought on e-bay.... and yes, the sunroof doesn't work..........
Old Apr 27, 2012 | 12:44 AM
tshorty454's Avatar
SOunds like i will try to use some grease! thanks for the input, i will try it tomorrow!
Old May 2, 2012 | 06:35 PM
70monte1's Avatar
Mine was doing the same and I degreased and greased with white lithium and it only worked for a little while. I then called the dealer and asked them what they recommended for the sunroof rails and he said that they found that vasoline works the best. I degreased again and used Vasoline and my sunroof works fine now and has for awhile. I guess time will tell.
Wayne
ladyvyxen
Jan 14, 2013 08:28 AM
tshorty454
Jun 8, 2012 12:49 AM
punisherss
15
Dec 29, 2010 06:02 PM
Blue_wolf
Feb 8, 2009 10:51 PM
ckerdflag
Jun 1, 2007 09:59 AM
