Engine smell
Old Nov 25, 2010 | 04:08 AM
Redline29's Avatar
Default Engine smell
hi im new to the forum, just purchased a 2000 Monte Carlo SS with 125k miles on it. was driving it on the freeway today (driving a little hard for fun), then parked it at home. noticed a burning smell from under the hood. did a little research and came to the conclusion that it may be solved by:
A) replacing the intake gasket
B) flushing dexcool coolant and putting in standard green coolant/get oil change
C) continue driving it till smell doesn't return assuming that when the mechanic changed the oil he may have spilled some and the engine heat is burning it off.
D) a combination of the above.
what im asking is what it most likely could be, and if anyone has had the same problem and had it fixed in one of these fashions or another. i bought this car used but the previous owner took care of it very well getting regular service ever 3-4k miles, so im hoping its nothing too serious like replacing the intake gasket. any input is appreciated, thank you guys!
Old Nov 25, 2010 | 04:24 PM
Redline29's Avatar
nobody knows?
Old Nov 25, 2010 | 04:31 PM
mrl390's Avatar
Its thanksgiving, not alot of people are on here right now. Just be patient. First off, what does it smell like, burning oil or burning coolant?
Old Nov 25, 2010 | 04:53 PM
Overdose666's Avatar
Well if the car hasnt received t recall repairs then it could be fuel leaking onto the exhaust pipe
Old Nov 25, 2010 | 06:40 PM
Sparky-88's Avatar
Or burning rubber / plastic / brake pads?? Need more info.
Old Nov 26, 2010 | 06:37 AM
Redline29's Avatar
dealer told me it was newly installed brake pads. it also doesn't smell sweet so im assuming its not coolant. but all day today the smell never came back. so...now im confused lol.
Old Nov 26, 2010 | 09:02 AM
Sparky-88's Avatar
Maybe they spilled some fluid that got burned off causing the smell. Keep an eye (& nose) on it. Check for fluid leaks after it's been sitting just in case.
Old Nov 26, 2010 | 09:55 PM
Redline29's Avatar
bad news on the update of my monte. check engine light came on. now im stressed. i faintly smell a burning smell. i was watching my gauges and it seems to act strange. when im idle the gauge shows the engine oil level a little below halfway, but when i step on the pedal the gauge shows the engine oil level climb to about a bar or two above the middle. the temperature gauge sometimes stay a bar below the middle then slowly raises if im just idling. when the gauge hits the middle it very slowly goes down about a bar then stops then slowly goes back up to middle. it repeatedly does that over and over when im idle.. when im driving the temp gauge is pretty much normal. i popped up the hood after the check engine light goes on and with all my gauges doing that and noticed that the coolant level is a little higher. is this normal with the gauges? has this ever happened to anyone? thanks again for the input.
Old Nov 27, 2010 | 12:43 AM
Redline29's Avatar
i guess it's time to go get a diagnostic test.
Old Nov 27, 2010 | 12:59 PM
Redline29's Avatar
and now this morning the check engine light is off..........
DA
Dec 29, 2007 10:29 PM
ffriccio
Jul 1, 2007 09:06 PM
24_48Fan
Nov 28, 2006 08:25 PM
Scott 41
Oct 21, 2006 02:44 PM
dvick01
Jul 28, 2006 07:18 PM
