engine loud ticking noise at idle
Old Feb 2, 2024 | 08:55 PM
Chillest_Fern's Avatar
Default engine loud ticking noise at idle
i had to replace my fuel pump because my original one caused my car to not crank now i hear a ticking noise i think around the alternator area but i can’t really tell
i have a 2001 monte carlo ss with the l67 swap
File Type: mov
Old Feb 3, 2024 | 07:08 AM
Id probably start with the easy thing and pop the belt off and give it a start (just for a few seconds as the water pump won't be running).
If its still ticking, I'd pop the valve covers next and give all of the rockers / pushrods a wiggle test.
Old Feb 3, 2024 | 08:54 AM
yesterday i popped the supercharger belt off and heard it still heard it i was figuring maybe i should try that, sucks because i just got it back after 3 different mechanics working on my car i had water pump replaced, lifters, what ever a headset is too
Old Feb 3, 2024 | 09:04 AM
Yeah, I'd at least try the accessory belt too. Definitely a long shot as most of that stuff shouldn't tick, but at least you'd eliminate all of the accessories in just a few minutes of testing.
Id bet you're going to be pulling the valve covers though. Hopefully a rocker bolt just loosened up or something.
Old Feb 6, 2024 | 07:11 AM
zucchi's Avatar
Agreed. You're gonna need isolate where the noise is coming from; the engine OR the accessories (i.e., water pump, AC compressor, alternator, power steering pump, etc.)
Old Apr 21, 2025 | 08:42 PM
Sorry late reply it was rod knock
Shandley
Feb 9, 2019 09:16 AM
sixscarlo
May 27, 2012 06:56 PM
DRuben
Jul 15, 2011 09:22 AM
pizzarrhea
Mar 9, 2010 01:02 PM
roboticboredom
Nov 26, 2008 04:26 PM
