Emmisions code caused Check Engine light.
Old May 6, 2007 | 12:59 AM
Bigg J's Avatar
Default Emmisions code caused Check Engine light.
So, I noticed last week that my CEL came on for no apparent reason and decided to take it to the stealership to get it checked out. A few days passed and I hadn't taken it in yet. On my way home from work one night, I decided to stop in at Autozone for a code read.
The guy plugged in and scanned and came up with "High Volume Emissions Leak." Since I had no idea what exactly that meant, of course my eyes bugged out of my head. He asked me when the last time was I put gas in the car.I told him about 5 days ago (at the time). Then he asked when the light came on.I told him about 4 days ago (also, at that time). Then he had me open the gas lid and check the cap. It came right off.I hadn't replaced it correctly (that's what I get for rushing). He told me to drive around for another day and the code should automatically reset itself. The next afternoon, all was clear.
I just thought it was cool that the electronics were able to detect that the gas cap was not properly replaced.
The moral of the story, KEEP THOSE GAS CAPS TIGHT! 3 CLICKS.
Old May 6, 2007 | 12:30 PM
mickey's Avatar
Default RE: Emmisions code caused Check Engine light.
LOL hey at least you found out with out having to pay for it. My father in law got nailed for 50.00 to find that out LOL the check engin light came on for the window washer fluid.
So if you ever get one of thsoe make sure you chek the washer fills and also i know there is anotehr oen but cant remeber what it was.
his car will thow a code for a bad tail lights.
he has since gotten rid of it in favor of a truck LOL
Old May 16, 2007 | 09:26 PM
InTheIROC's Avatar
A car cannot throw a check engine light for low washer fluid or bulbs out. A check engine light is set if there is a fault that causes higher than normal emissions levels.
Old May 17, 2007 | 07:21 AM
wiz kidd's Avatar
yah i've heard of the gas caps throwing check engine lights
even guy's that do emissions tests come in and buy new ones sometimes ...lol
Old May 17, 2007 | 06:48 PM
mickey's Avatar
ORIGINAL: InTheIROC
i can prove this fact for ya that is will on your car also unless they have changed it in the )3 model like mine if you unplug the high beam on the car it will throw a code on the DIC. and also flash highbeam out on your dash at you. Everytime you start the car,
His didnt have this type of dash it was just a idiot light and it actually would throw a check engin light for you every time the washer fluid would get low.
The Montana mini van we had did the same thing even for the rear washer fluid resivor
KWJR86
Jul 12, 2021 12:31 PM
el pachuco
Jul 30, 2015 12:47 PM
rockieg00
Oct 1, 2009 01:35 PM
TORONTOLSMONTE
Jul 5, 2009 07:04 PM
mtwallet
Jul 5, 2008 11:00 PM
