Electrical U Codes?
Old May 29, 2014 | 12:37 PM
Brendocee55's Avatar
Default Electrical U Codes?
My 2003 Monte Carlo has 2 U codes, one of them is the U1300 and the other one is U1064. As im driving all my gauges will go off and my security light, battery light, service vehicle soon light, low fuel light, and my airbag light will come on for about 5-10 seconds. Then everything will go back to normal but my security light will stay on. What could be causing this to happen?
Old May 29, 2014 | 01:32 PM
A bad ground, or your BCM likely.
Old May 30, 2014 | 07:01 AM
03SSLE's Avatar
A bad ignition switch will also create the symptoms you describe.
Old May 30, 2014 | 10:49 PM
Ahhh yes, occaisionally i will go to turn over my car but it wont crank but after a few times it will finally turn over, not too sure what that is
Old Jun 1, 2014 | 09:46 AM
FYI - I moved this out of the "MCF Problems & Issues" section as this topic is not related to a forum problem. It's now in the "Monte Carlo Repair Help" section.
Henderson21
Jul 26, 2014 03:37 PM
erik2282
Oct 7, 2007 01:00 AM
BLACK ATTACK
Sep 5, 2007 07:49 PM
djplayap
Aug 1, 2007 09:54 PM
scc24540
May 21, 2007 07:48 PM
