6th Gen ('00-'05): Electrical dies but engine stays running
I have an 03 Monte Carlo SS and rarely, but often enough to post about it now, I’ll have the engine running and all of a sudden the radio will shut off and all my gauges go to 0 on the dash. Engine is still running and I can drive it just fine, even tho tachometer and speedometer and every other gauge is in it’s far left position. Even the gear shift lights are off. Maybe 2-3 minutes later, everything comes back online.
My question is if anyone knows what could cause this, what I can do to fix it, and if anyone’s even had this issue before.
Thanks.
Thanks.
I had a similar issue with the AC blower stopping but it would start blowing again if I turned it off and then on to full speed and down to 2 or 3. It turned out to be the ignition switch and I haven't had a problem with that since.
TThrasher
Apr 29, 2017 12:02 AM
7th Gen ('06-'07): Engine bogs down and car lunges forward when decelerating
nicks_monte
Apr 4, 2014 11:56 AM
crete
Jan 2, 2012 04:24 PM
