Electric Water Pump.....
Old Apr 12, 2005 | 06:41 PM
montejass's Avatar
Default Electric Water Pump.....
ZZP Link
Worth an extra 7HP.....
The end of my warranty can not come soon enough..
TVW
Old Apr 25, 2005 | 05:45 PM
mickey's Avatar
Default RE: Electric Water Pump.....
looks nice but OUCH nice price also.279.00
Old Apr 25, 2005 | 06:21 PM
Boost's Avatar
DAMN!!! thank god the one for the small blocks is only $150.00
Old Apr 25, 2005 | 07:11 PM
Patrick's Avatar
gentlemen...if i may...as some of you may know, i have a non-monte that a have spent the last few years in running a national drag racing series....it is a dodge small block, and i bought a water pump driver from moroso...it was MUCH cheaper than the full electric water pump, and it used the pre-existing pump. it took almost no time to install and im sure they make one for everything..they are fairly universal...it is just a small motor and pulley that mount next to the water pump, and you run a toothed belt from the motor to the pulley that they include.
Old Apr 25, 2005 | 10:32 PM
montejass's Avatar
That sounds like a pretty cool add on....
How hard was it to fab a mount for that thing or was it a kit specifically designed for that motor? I'll have to do some hunting around for this one... Good idea...
TVW
Old Apr 25, 2005 | 10:48 PM
Patrick's Avatar
mine came with the motor, the pulley for the pump side, the belt, a bracket, and a TON of bolts of all different length. the directions had a picture of the bracket in like 20 different positions and said below each picture, for instance
[picture]
small block chevy
[pitcure]
small block mopar
[picture]
v6 mopar
so on...and then you contorted it to fit and be tight enough with the belt..it works great..it has an attatchement to turn on when the thermostat opens, but i jst wired a switch into my switch board....i prefer to control it, and when i run the only pwoer drawing item that i have is my HV fuel pump. considering the popularity of the 3800 series, i would expect that someone woudl make one for your car, and if not, all would would have to do it have a piece of metal cut that you could use for a bracket, and the bracket is similar to a tesnioning bracket on an old alternator.
tkay_z34
Mar 31, 2008 10:17 AM
wnmech
Mar 29, 2008 07:19 PM
sportjunkee
Jan 13, 2008 07:13 PM
motivation2k3
Oct 18, 2007 06:16 PM
Brooke
Oct 17, 2007 04:35 PM
