dome light
Old Feb 25, 2007 | 07:18 PM
Monte_04's Avatar
Default dome light
How do u take off the dome light to change the buld (04 monte)
Old Feb 25, 2007 | 08:30 PM
benhillzone3's Avatar
Default RE: dome light
that is a good question considering i have that same year lol
Old Feb 25, 2007 | 08:32 PM
Monte_04's Avatar
i dont want to pull and break somthing off.
Old Feb 26, 2007 | 04:33 AM
enibum's Avatar
Does it mention it in the owner's manual? I'm at work and can not look at it right now.
Old Feb 26, 2007 | 03:27 PM
Monte_04's Avatar
No, not unless i missed it. it just tells me the type of bulb.
Old Feb 26, 2007 | 09:16 PM
FlynhghR's Avatar
Hey There Monte, I had a 2003 Monte and if I remember correctly you had to slide the housing back and pull down. When it's far enough back it should just 'pop' off. It's kind of scary but it's not very complicated. Just don't put so much force the whole headliner starts to pull down. It takes more than you'd think, but not enough to pull the whole headliner down. I removed it one day just out of curiosity. To put it back on it's the same, start more towards the back and just snap it on, then slide it to the correct position. It should slide pretty easy once the plastic cover is snapped in place.
Old Feb 26, 2007 | 09:26 PM
Monte_04's Avatar
ok ill try that thanks.
Old Feb 28, 2007 | 11:39 AM
big green dog's Avatar
Monte Of The Month - July 2005
man it seems like i have to wrestle mine out dont even have it all the way back in right now i got so frustrated with it guess ill try to fix that today
Old Feb 28, 2007 | 05:03 PM
Monte_04's Avatar
slide the shel in first, then put the clear plastic in thats what worked for me.
KrackerJ
Jan 23, 2008 12:06 PM
GooberMT
Jul 4, 2007 02:53 AM
Monte_04
Feb 26, 2007 09:32 PM
01BlkSS
Dec 25, 2006 04:18 PM
big green dog
Jul 7, 2006 02:12 PM
