dome light
Hey There Monte, I had a 2003 Monte and if I remember correctly you had to slide the housing back and pull down. When it's far enough back it should just 'pop' off. It's kind of scary but it's not very complicated. Just don't put so much force the whole headliner starts to pull down. It takes more than you'd think, but not enough to pull the whole headliner down. I removed it one day just out of curiosity. To put it back on it's the same, start more towards the back and just snap it on, then slide it to the correct position. It should slide pretty easy once the plastic cover is snapped in place.
