Do I want to do the downpipe swap?
Old Jul 15, 2010 | 09:09 AM
Id say, take a look at milzy to see if he could delete the code... But uh... Yeah.
When you have a 3800 you can use other options than Milzy thankfully
Old Jul 16, 2010 | 03:54 PM
I'm not sure what the delete from the PCM would do to that report.
If the code is set correctly in the pcm; you will still pass emissions, even if you have no cat (assuming they don't happen to do a visual check). I passed IN emissions with no cat on my old GTP- they plugged into the pcm only, and it passed just fine (I fixed the codes with my powrtuner- the same thing the stores do when they tune them).
Old Jul 16, 2010 | 04:45 PM
Enzo354's Avatar
STILL SLOW
Old Jul 16, 2010 | 06:02 PM
Yeah, but that's $60, and an aftermarket pcm is only $40 more- and it gives you a lot of other benefits too.
Budsjlm
Apr 3, 2012 05:43 PM
my00monte
Mar 30, 2011 04:14 PM
mrl390
Dec 19, 2007 05:27 AM
jay26
Apr 20, 2007 10:09 AM
nj85z28
Jan 27, 2006 10:00 PM
