Dip Stick Reading
Old Oct 4, 2008 | 08:13 PM
vikinghaux's Avatar
Default Dip Stick Reading
Well I recently did a head/LIM gasket change. Got everything back together and the engine is running fine. I did an oil changed as recommended, K&N and Valvoline Syn Blend. In the process of the gasket change I had to remove the dipstick in order to remove the head. I started w/ 4qts of oil and the dip stick was only reading 1 qt. I put in an extra qt so 5 total but the dipstick reading has not changed at all. I don't want to put more oil in and I don't want to run on low oil. I'm sure that I have no leaks. Is the dipstick not reading the oil level correctly? Not sure where to go with this one any help would be appreciated.
Old Oct 10, 2008 | 06:30 PM
04 Intimidator's Avatar
Default RE: Dip Stick Reading
I would make sure the dipstick cylinder has not been pushed up at all, that might give the false reading.
mowparz
Dec 23, 2013 01:58 PM
lanniec
Jun 23, 2011 09:52 PM
TurboV6MC4Life
Oct 28, 2008 08:41 PM
jeffsmonte
Aug 8, 2008 09:42 AM
1978monte
Sep 11, 2007 10:25 PM
