Dashboard Lights,Radio Lights And Rearlights Dont Work???
Old Oct 12, 2010 | 10:59 PM
spiknek's Avatar
Exclamation Dashboard Lights,Radio Lights And Rearlights Dont Work???
hey guys my need help ?
my dashboard, radio and rear lights dont work if i try to dim them with the dimmer notin happens (but brake lights work fine) can someone help me on this please.
2001 MC.
thanks
Old Oct 13, 2010 | 12:01 AM
04MonteLS's Avatar
So, did this just happen out of the blue or was it after you did something on or to the car? Did you check the fuses?
Old Oct 13, 2010 | 11:20 AM
spiknek's Avatar
yeap i chk fuses but it happen right after i re plug the fact amp??
any clues?
Old Oct 13, 2010 | 02:29 PM
04MonteLS's Avatar
why did you unplug the amp?
Where were these fuses that you checked?
Old Oct 14, 2010 | 08:21 AM
spiknek's Avatar
i have had the fact amp umpluged so i was putting everything back together the fuses i chked where driver side pass side and under the hood?
Old Oct 15, 2010 | 11:09 PM
spiknek's Avatar
prob solved one of fuses was giving me false reading it was a fuse
thank you all!
Old Oct 16, 2010 | 07:54 PM
Monte SSV's Avatar
Default Same issue
Spiknek: I have the same problem with my car, an '02 Monte. Dash lights don't work - dimmer switch doesn't work - radio lights out. I did look at all the fuses - they looked good - which one gave you the false reading? Might be the same problem I am having although my lights just stopped working one day.
Old Oct 27, 2010 | 09:18 AM
spiknek's Avatar
on the driver side it was a red 15amp one! (rear prk light).
hope its the same and it fixes your problem.
Old May 7, 2011 | 08:30 AM
BuckeyeBrad's Avatar
Same problem on my 2000 Monte SS and I will need to check that Rear Parking Light fuse also.
Old May 9, 2011 | 11:57 PM
DChronos's Avatar
Reading this quick, I have a 1996 Monte that I've been working to fix a bunch of problems on, and one of the problems, related to this, was that the dash lights, radio, and shifter light would go out when turning on the parking and headlights, but the dome light and all others on the outside were working fine. I thought it was a short somewhere under my dash, as back when it first started happening, the lights would flicker and eventually just come on while driving down the road, or when I smacked the top or bottom of the dash a few times.
But instead, something was apparently broke or worn out inside the dimmer/headlight switch box itself, though nothing looks or feels broken. I just stuck in a replacement from a DIY parts junkyard place and they all work like when I bought the car 6 years ago.
So if anyone else happens to have similar problems and don't see anything wrong with the fuses, believing there's a short somewhere, save yourself some time and check there first... that might just be all that's wrong, too.
Unfortunately, I have another strange lighting issue with all lights, but that's in another thread.
redbird555
May 18, 2014 08:17 AM
PhoenixAZMC
Jun 16, 2012 03:39 PM
96MonteCarloZ34
Jul 29, 2010 05:30 PM
darren700
Jun 3, 2010 05:59 PM
situation
Jun 12, 2007 07:36 AM
