Dashboard Lights,Radio Lights And Rearlights Dont Work???
hey guys my need help ?
my dashboard, radio and rear lights dont work if i try to dim them with the dimmer notin happens (but brake lights work fine) can someone help me on this please.
2001 MC.
thanks
2001 MC.
thanks
Spiknek: I have the same problem with my car, an '02 Monte. Dash lights don't work - dimmer switch doesn't work - radio lights out. I did look at all the fuses - they looked good - which one gave you the false reading? Might be the same problem I am having although my lights just stopped working one day.
hope its the same and it fixes your problem.
Reading this quick, I have a 1996 Monte that I've been working to fix a bunch of problems on, and one of the problems, related to this, was that the dash lights, radio, and shifter light would go out when turning on the parking and headlights, but the dome light and all others on the outside were working fine. I thought it was a short somewhere under my dash, as back when it first started happening, the lights would flicker and eventually just come on while driving down the road, or when I smacked the top or bottom of the dash a few times.
But instead, something was apparently broke or worn out inside the dimmer/headlight switch box itself, though nothing looks or feels broken. I just stuck in a replacement from a DIY parts junkyard place and they all work like when I bought the car 6 years ago.
So if anyone else happens to have similar problems and don't see anything wrong with the fuses, believing there's a short somewhere, save yourself some time and check there first... that might just be all that's wrong, too.
Unfortunately, I have another strange lighting issue with all lights, but that's in another thread.
PhoenixAZMC
Jun 16, 2012 03:39 PM
96MonteCarloZ34
Jul 29, 2010 05:30 PM
darren700
Jun 3, 2010 05:59 PM
