6th Gen ('00-'05): Crank but no spark
Old 07-05-2018, 08:41 AM
Here is some more shop manual data. Sounds like you are on the right path, needing to check out the crank and cam sensors. Hopefully the PDFs help get you closer to an answer.
Old 07-05-2018, 03:26 PM
EvanLauer's Avatar
Thanks, I appreciate it. Shop is gonna check it out with their scanner tomorrow morning, hopefully that throws something.
Old 07-06-2018, 10:20 AM
Great info Maniac, thanks!
Old 07-07-2018, 08:24 PM
EvanLauer's Avatar
Wound up being the wire from the ICM to the crankshaft sensor. They did a little workaround that got it running (they're gonna properly rewire it soon, because I have no desire to do that), but it's throwing a misfire code now. I have a feeling the crankshaft may be dead as well, or might need a relearn now.
Old 07-09-2018, 12:34 PM
EvanLauer's Avatar
So when I wired the ground wrong, I had the wiring harness in the wrong spot. Turns out the belt ate through the harness. The rocker arms also weren't torqued correctly, so I need to do a better job with that. The bolts were apparently almost all the way out when they fixed it. Thanks again Maniac for all the PCM help.
Old 07-12-2018, 10:09 PM
No problem on the help. I do what I can.
Happy it sounds like these issues are now behind you
schoentges16
02-27-2021 06:43 AM
dubb_b
01-19-2017 10:46 AM
Nightmagic11801
03-11-2014 10:04 PM
phate1606
06-02-2012 06:10 PM
Selwen
08-19-2011 09:58 PM
Quick Reply: 6th Gen ('00-'05): Crank but no spark
