coolant leak
I found this online. reading through it I think it looks pretty simple. Ive heard its a little tricky tho. http://www.automotiveforums.com/t915...99_and_up.html
Im sure some members will have some tips to make it easier.
Easiest way for a first timer IMO - remove alternator, remove the bracket under the alternator, or loosen the bolts, so you can have some wiggle room to replace the elbow. Make sure none of it is broken off, if it is, make sure you get the broken part out of the intake
They just came out with new aluminum ones you can get from rockauto link----------> RockAuto Parts Catalog
Or get the gm ones. I had the plastic dorman ones fail in 2 months for me.
2000LS
Jan 28, 2008 08:00 PM
