Coolant Elbow Help?
Old Apr 3, 2013 | 08:45 PM
Dylan313's Avatar
Default Coolant Elbow Help?
Hey guys, I have an 02 SS and I'm getting ready to have a mechanic friend do the upper and lower intake gaskets(surprise, surprise...) I read that I should pick up the coolant elbows for the water pump as well since they frequently break when being removed. Can I get them at Auto Zone? Are they a certain size? I checked their website and can't seem to fine them, what do I ask for?
Thanks in advance, Dylan
Old Apr 3, 2013 | 08:59 PM
The 3800 is the only car (I know of) with coolant elbows. You have 3 options:
1 - Dorman replacement plastic elbows. Parts store, about $5-$10
2 - Dorman replacement aluminum elbows. Parts store, about $5-$10
3 - GM replacement plastic elbows. Dealer item, about $30
Some stores may not have option #2, but I've seen option #1 at ALL major parts stores.
Now, Dorman has had a lot of people about a year or two ago complaining their elbows were "popping" out. Allegedly, they had a run with incorrect O-rings. I ran a set one spring, parked the Monte for winter, next spring first ride into work, and an elbow pushed out. I replaced with a GM elbow set, so far so good (see how it holds up this year). The castings of the elbows are different, but I don't know if that makes a difference.
If you are going Dorman, get the aluminum ones (they should last a lot longer). Heck, I have a set of aluminum ones as spares in my garage right now....
Old Apr 3, 2013 | 09:14 PM
Dylan313's Avatar
Thanks a lot man!
Old Apr 3, 2013 | 10:06 PM
bobkl's Avatar
plastic dorman part # 47065 4.99
Aluminum dorman part # 47065hp 11.99
these price are from oreilly auto parts web site
Old Apr 3, 2013 | 10:36 PM
Dylan313's Avatar
appreciate that, boss
Old Apr 23, 2013 | 07:56 PM
odell1957's Avatar
Default coolant elbows
is the dealer ones better and are they metal ones?For $30 should be metal.
Old Apr 23, 2013 | 07:58 PM
odell1957's Avatar
i see now you said plastic from dealer
Budsjlm
FWD Tech Guides '95-'07
Oct 29, 2015 05:01 PM
owens91
Mar 13, 2014 10:50 PM
turbo monte
Feb 23, 2014 11:15 PM
ohara
Sep 13, 2013 09:06 PM
blueSS
Jun 5, 2012 05:30 PM
