Coolant?
Old Jun 8, 2009 | 03:45 PM
Weber's Monte's Avatar
Default Coolant?
Can you put regular coolant into a dexcool system. Because i want to flush my coolant system but im not shure if i can use regular coolant.
Old Jun 8, 2009 | 05:16 PM
baja216's Avatar
NO!, I heard they are not compatible.
Old Jun 8, 2009 | 07:24 PM
kweef's Avatar
if the system is flushed there should b no dexcool for it to mix with
Old Jun 9, 2009 | 02:44 AM
Im going to completley flush it but im wondering if i can refill it with regular coolant.
Old Jun 9, 2009 | 09:48 AM
RickAKATed10's Avatar
Photobucket
Yes. As long as it is completely flushed. You can't mix though.
Old Jun 9, 2009 | 09:58 AM
as long as you know for sure that you got all of the dexcool out, you can then use whatever fluid you want.
However, if you don't get every drop of dexcool out, the new coolant will mix and turn into a sludge-like substance.
Old Jun 9, 2009 | 06:50 PM
MAMONTE's Avatar
Yes, you can put any coolant in after making sure ALL of the Dex-cool is out...I've done it in my mom's Bonneville. I switched it to that Prestone All makes all models coolant. So far no problems after 40K
mayerichm
Mar 3, 2006 11:16 AM
01whitess
Jan 9, 2006 11:39 PM
GTown
Nov 11, 2005 11:27 PM
Birge
Dec 30, 2004 03:09 PM
RudeRooster
Sep 30, 2004 11:49 PM
