Which Code Reader?
Those options are pretty much what my scanner can do. Admittedly, I don't have the gravity sensor on my computer, but everything else.
I constantly have my scangauge 2 monitoring MPH, KR, IAT, and Water Temp.
My Camaro's speedo falls slowly, I need to know whether to shift to 1st or 2nd, the live-feed tells me better than the needle.
I also like to keep an eye on KR so I know if my tunes need help.
So i ended up going with the Equus 3150. I really needed ABS support as my light was on and I was sick of randomly replacing parts. Turns out it wasnt the hub like i thought (already replaced both of the fronts.) Its a ground wire that is tripping all the ABS lights. Thanks to the reader I know this now. Backlight is actually more b.a. than I thought it would be. Lots of features and easy to use! Highly recommended!
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
Your manual will tell you how, but basically you start the process through the dash, then you let air out of the new front left tire until it beeps, then move to front right, then rear right, then rear left. Once they all beep you are done! Then put them all back to the right psi
Chris, if it is for your car, you can do the relearn yourself ![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
Mike, I have only tried this once without it working correct for me. There have been a few members here who have also tried and didn't get it to work correct also? I was just hoping for an easier way to do that....
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
I also was considering getting this TPMS trigger tool from tirerack?
CUB TPMS Trigger Tool
![](http://www.tirerack.com/images/tpms/search/small/cubtool_s.jpg)
- For many GM vehicles
- Easy-to-use right out of the box
- Triggers newly installed sensors
I dont know if it has the feature to retrigger that. Im assuming no but there is a ten dollar add on for my car, but im not sure what thats for. Ill find out tomorrow and get back you.
RickCoMatic
02-26-2008 01:56 PM
RickCoMatic
02-18-2008 03:33 PM
RickCoMatic
02-15-2008 09:38 PM
