Jones's GTP Thread
Old Feb 29, 2012 | 12:40 AM
jwjones's Avatar
Default Jones's GTP Thread
So after so much updates on this car I decided to make a thread.
Here's what I did today....
Today I went outside to replace the cracked coolant elbows on my car, after about 30min of removing the belt, alternator, and tensioner I managed to pull the old elbows out and from what I saw looked like a horror story. They were broken on the ends and sealed with RTV for a temp fix by the previous owner. I installed new elbows and now the car no longer leaks coolant.
After that I decided to tackle the TPS issue that's been on going. After a long fight with this sensor it came down to the wiring harness. I had to go to GM and spend $40 on a new harness. I got home started peeling away all the tape and pulled the wires, clipped them and connected the new harness. Started the car and VIOLA! The car idled perfectly just like it should have. Took it around the block and shifted smooth as butter and I could feel a gain in power back for sure!
Here are some pics of my handy work. I wanted to make sure that when I was done that it would look like I never even touched it, I'd say I did quite a good job wouldn't you say?
Old Feb 29, 2012 | 04:11 AM
JW, Your Monte Carlo Family is so proud of you ~>4-Sure Good Job, looks like you never even touched it.
It's great that you have the knowledge & talent to do your
own work & save Big $'s
Old Feb 29, 2012 | 06:40 AM
Cool Glad you got it all fixed up. Ihave heard the coolant elbows can be a real PITA to change. what do you think?
Old Feb 29, 2012 | 09:29 AM
jwjones's Avatar
Thank you Space!
No they really aren't that bad to replace, once you get the belt off, tensioner off, and alternator off it real easy they literally pop right off. However what the How-To threads don't tell you is that you WILL lose coolant when doing this, so buy about 1 jug of coolant. The tensioner has a jacket the coolant passes through to get to the LIM which is where the elbows are attached. Really all you have to do is make sure they line up correctly and push them in. Out of the whole precedure I had to remove 8 bolts and 2 of which were what held up the coolant overflow. There is one bolt hidden on the tensioner towards the firewall, you'll have to feel around for it but you'll find it eventually. Overall I wouldn't mind doing the job again, was pretty easy.
Old Feb 29, 2012 | 10:22 AM
Well that's good I have never changed mine yet so i'm sure someday they will go bad. I think I'm gonna buy a set so I have them.
Old Feb 29, 2012 | 10:31 AM
04chevyboy's Avatar
Good work man,anything you can do your self to save money is always great
Old Feb 29, 2012 | 10:37 AM
I have a set in my trunk in a milk-crate along with all my other "possible problem solutions".
I would recommend doing a flush when changing the elbows, this way you don't have to add new coolant with old coolant.
jwjones
Jun 15, 2012 04:43 PM
lougreen03
Mar 1, 2012 07:16 AM
jwjones
Apr 17, 2011 12:42 PM
zipsayain
May 26, 2008 10:31 AM
04 Intimidator
Mar 4, 2008 11:40 AM
