cluster
A fuel sending unit isn't part of the fuel pump? Plus I called the dealer about the cluster n they said there isn't n in between as far as gauges go they are either working or not no in between. Is that true? Id think so considering they'd want my business but I'm not sure
Ok I took my car to the dealersip to have the cluster checked n they told me its fine... they said its either the sending unit or the wire conecting the sending unit to the gauge...either way I'm getting it done for free my pump is still under warrenty...hey 1 more question if a fuel pump is going bad will it also send too much fuel to the engine thus poor mpg as well?
What about the regulator...no one can pin point the problem
