cluster
Old Jul 20, 2010 | 11:11 PM
02montecarlo's Avatar
Question cluster
Hey I have an 02 ss n I'm thinking my fuel gauge is messed up its not reading correctly n its not the fuel pump I know for sure. Is there a fuse I can check or do I have to replace the whole damn thing?
Old Jul 20, 2010 | 11:32 PM
nemesis's Avatar
2009 Monte Of The Year
there's a small motor inside all the gauges the one for the fuel probably need to be replace.
Old Jul 21, 2010 | 08:12 AM
There's something called the fuel sending unit that will probably need to be replaced.
I believe we have a how-to on it.
Old Jul 21, 2010 | 06:36 PM
A fuel sending unit isn't part of the fuel pump? Plus I called the dealer about the cluster n they said there isn't n in between as far as gauges go they are either working or not no in between. Is that true? Id think so considering they'd want my business but I'm not sure
Old Jul 23, 2010 | 01:40 PM
Ok I took my car to the dealersip to have the cluster checked n they told me its fine... they said its either the sending unit or the wire conecting the sending unit to the gauge...either way I'm getting it done for free my pump is still under warrenty...hey 1 more question if a fuel pump is going bad will it also send too much fuel to the engine thus poor mpg as well?
Old Jul 23, 2010 | 02:07 PM
A lot of factors with MPG
Old Jul 24, 2010 | 01:12 AM
lucian*91's Avatar
the sending units are common problems on monte carlos and impalas. and i cant see it giving you bad mpg because of the fuel pressure regulator
Old Jul 24, 2010 | 01:26 AM
What about the regulator...no one can pin point the problem
Old Jul 24, 2010 | 01:35 AM
lucian*91's Avatar
if the pressure gets too high, the regulator will release the extra pressure back. what is your mileage?
Old Jul 24, 2010 | 01:42 AM
I'm getting about 13-14 right now
