Clunking noise, not CV axle
Old Dec 6, 2016 | 12:18 PM
Dj_bosse's Avatar
Default Clunking noise, not CV axle
Whenever I back out of a parking spot I hear a clunking noise (only a very low speeds). It only happens when I turn the wheel clockwise. My first thought was it was a CV axle on the driver's side, but I replaced it and it's still making the noise. I've also recently replaced the passenger side CV axle, both tie rods, and driver and passenger side control arms due to high mileage (219,000). Apart from the possibly that my remanufactured CV axle already failed, what else could be causing this?
Old Dec 6, 2016 | 01:52 PM
turbo monte's Avatar
How about your strut mounts? Broken coil spring? Tie rod ends? Wheel bearing?
Old Dec 6, 2016 | 02:44 PM
Dj_bosse's Avatar
Bearings are new all around. New tie rod ends and I checked the strut mounts and spring when I replaced the CV axle
Old Dec 6, 2016 | 06:41 PM
nitehawkjcb's Avatar
Could be another bad axle, or possibly a steering rack issue.
Old Dec 7, 2016 | 01:17 AM
96z34man's Avatar
Intermediate steering shaft?
